Discussion topic: Pixelating on Netflix after splitting router frequencies
Message posted on 08 Oct 2024 03:35 PM
Hi, we have recently moved over to full fibre 150 WiFiand had to unsync the 2.4Ghz and 5Ghz frequencies so that all the different type of devices could connect (still having trouble with solar panel app) . Thought we had read other comments about this sometime affecting tv and we have noticed Netflix is pixelating since we split the bands. Does anyone know whether it's just a coincidence or a result of splitting. Can't seem to get sky box to connect to 5Ghz, automatically connects to 2. Thanks
Message posted on 08 Oct 2024 04:38 PM
Re: Pixelating on Netflix after splitting router frequencies
@LynnW1 thec2.4GHz band can carry less data and is more prone to intterference than the 5GHz band so if your Q box is connected using thst band that is the likely cause of your Netflix issues. If you have one of the black hubs itvshould connected to the 5GHz band but try connecting by using the non-Sky option and choose the 5GHz SSID manually and enter the password thst way rather than using wps.
Message posted on 08 Oct 2024 07:28 PM
Thank you 🙂 how do I connect using the non-sky option?
