Discussion topic: Phones not connecting to wifi
Message posted on 26 Oct 2024 07:42 AM
Hello,
I had an engineer visit yesterday to fix my broadband (issue was low speed and kept dropping out). Since his visit, no iPhone have been able to connect to WiFi. Other things like Netflix, Amazon Prime etc all work. Just unable to connect iPhones. I have reset everything and also reset the network setting but nothing seems to work.
can anybody help?
thank you
Message posted on 26 Oct 2024 08:20 AM
Re: Phones not connecting to wifi
@Rbt73 on one iPhone tell the phone to forget the Sky connection then power down the phone normally done by holding down the side button and a volume button down until the power slider appears. Then re-start the phone and add the Sky WiFi from scratch once one phone is networked then itvcan sharecthecconnection with other iphones.
I
Message posted on 26 Oct 2024 08:31 AM
Hi Chrisee,
thank you for your reply.
i have just tried this and has made no difference.
thank you anyway
