3
This discussion topic has been answered Discussion topic: Paying for wifi but can’t use it
This message was authored by: Tia2749
Hi, I've just moved into my first house so knew nothing about broadband or Sky. I chose a Sky Max Hub broadband fibre 500 package. Not one did they offe me for an engineer to come round, they didn't check I had everything I needed.
Now, after waiting 2 weeks for activation, I've come to activate the broadband and the power cable is missing to the ONT you have to connect so google is saying I need to contact Sky to get an engineer round. I cannot find a phone number for a real person with sky ANYWHERE. It is absolutely awful. I'm not paying for wifi I can't use.
Does anyone have a phone number I can contact or know how to get an engineer to come round.
I am fed up already.
This message was authored by: GD1 Answer
Re: Paying for wifi but can’t use it
@Tia2749   These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
@Tia2749 Sorry that has happened, but your responsability for everything internal to the home, not Sky or OR, some previous owners take them for some reason, at least they had the sense to leave the ONT there!
