Discussion topic: Pay for broadband home check
Message posted on 13 Apr 2024 10:29 PM
I seem to have non stop issues with my broadband it constantly going down, the broadband checker on my Sky states it fine. Before I cancel and go to BT wondering if its worth paying for sky to send an engineer to check our kit etc. I pay for a booster and nothing seems to work - in the past Sky has just said it's because you have too many connected devices - but I can't be any different from most - my sky Q relies on Bb, and we have 4 mobile devices- we don't game - thoughts
Message posted on 14 Apr 2024 04:47 AM
Re: Pay for broadband home check
Could you post your hub stats
If there is an external fault then sky can book an openreach engineer.which will be free of charge. If its more an issue with wifi and or the booster box sky can get their own engineers out to do a site survey to see if amy more boosters would be advisaable this would also be free as you are already paying for it
Message posted on 15 Apr 2024 11:01 PM
Message posted on 16 Apr 2024 12:30 AM - last edited: 16 Apr 2024 02:09 AM
Its clear theres an external line fault going by the noise margin of 14db , the upload speed indicates you could get as fast as 80Mbps.
Try running the service checker in your my sky app using 4g/5g mobile to get around the fact that your line is dropping all the time it should let you book an enginee
Message posted on 16 Apr 2024 02:41 AM
Have you got full fine because a booster with not make a difference if you're on a normal copper line. You should not have to pay for an engineer at all as their advise was wrong. Not just that - it's their equipment and have made it clear that any equipment you receive is there for you on loan while using the service. Are you in hardship and or a vulnerable customer? If so they have misplaced you the booster. Even if you do have full fibre, engineers should be free as they are responsible (sky) for anything that has gone wrong. Remember other than things you have actually bought, it is their responsibility and the booster hardly makes a difference anyway. Good luck and you fight your corner. They're a big company. It is important that you suggest that you cannot afford it due to hardship, even if your not because at the end of the day, if you could afford it, you wouldn't be concerned about them charging for a home check (that I've never heard of anyway). Good luck!
