30 May 2022 12:01 PM
Hi, I'm trying to use a third party router but i need the username and password from sky but the sky agent i spoke to over the phone said that they would not provide this and i would need to speak to the router manufacturer. Is there anyone on here that could provide me with this please?
30 May 2022 12:03 PM
What broadband package are you on fttp or fttc?
Are you in ireland?
What router do you have?
30 May 2022 05:05 PM
im on fttp in the uk with a TP link ax10 router
30 May 2022 05:16 PM
Tp link routers don't appear to support sky authentication ie sky mer, dhcp option 61, client id. Sky only supports PPPoE in Ireland
There is a possibility of getting it authenticated via dhcpv6 prefix delegation :-
Select both ipv4 and ipv6 on the wan
Select dhcpv6 dynamic (not static) on the wan
Enable pd/prefix delegation on the wan
For address creation on the lan choose stateless/SLAAC
30 May 2022 05:22 PM
Thanks for the help 👍 i'll give that a go, are other makes more compatible? netgear asus etc?
30 May 2022 05:25 PM
@Alex1927 wrote:Thanks for the help 👍 i'll give that a go, are other makes more compatible? netgear asus etc?
Seems that most success comes with Asus' models.
30 May 2022 05:26 PM
At the moment the following are very popular and all work with sky both dhcp 61 and dhcpv6 pd
Asus rt ax56u
Asus rt ax58u
Asus rt ax68u
Asus rt ax86u
Asus rt ax88u
Asus zenwifi xt8 mesh
30 May 2022 05:33 PM
Note that without a Sky Broadband Hub you cannot get access to the VOIP Sky Talk bundled with FTTP.
30 May 2022 05:40 PM
Used in access point mode you only lose adaptive qos for gaming, vpn on the asus and choose you own dns. Then you run the asus ethernet thru the sky hub
30 May 2022 06:44 PM
thanks for the replies all, im going to just use it as a access point for now until if/when i change ISP, or i upgrade the router 👍
31 May 2022 06:21 AM
If it helps I had a very simple setup with a Netgear Nighthawk and it has great coverage.
01 Jun 2022 09:00 AM
Did you need to enter any ISP username and password?
07 Jun 2022 09:58 AM
Posted by a Superuser, not a Sky employee. Find out moreThe Netgear Nighthawk series just require the input of the DHCP Option 61 string to connect
09 Nov 2022 10:47 AM
@BillyD97 Can I ask how you got that to work? Mine keeps asking for PPOe user and password and all the ones I have tried arent working. But from what I gather, I need to input these for me to get to the main settings for Option 61 etc?
19 Apr 2023 02:13 PM
Hi, I'm trying to use a third party router but i need the username and password from sky I have same issue as the previous user. My Sky package is Sky superfast 35 and my 3rd party router is UDM router. and i based in London.
When i was in BT, i used the BT equivalent and it worked the only thing is my voip phone was connected (doesnt matter)
