Discussion topic: PC and Android Phone cannot reconnect to SKY Router
This message was authored by Reb1sham2 This message was authored by: Reb1sham2
My Windows 10 PC, Samsung and Xiaomi phones are disconnected while asleep
and cannot reconnect after waking.
The SR203 router is working fine with 3 green lights and some other devices connected ok.
The problem seems to be that the Router does not assign an IP address to the devices trying to connect.
I assigned fixed address to all my devices but problem remains.
The devices show "connected to router" but "no internet connection"
Restarting the devices does not fix it.
Pressing the WPS button does not fix it
Power cycling the Router fixes it
I cannot do a reboot because my PC is not connected to control the router
It is an OK solution, but,  the 2-3 min disruption to all devices is annoying
Any better way?
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
Re: PC and Android Phone cannot reconnect to SKY Router
Posted by a Sky employee
Hi there, I have escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the blue bubble to start the conversation.
Lisa - Sky Tech Team Expert
Reb1sham2
I followed the link supplied  by @Lisa-P1987 to open a chat with Sky support UK
But as I am an ROI customer they said they would pass me over to ROI support team.
No progress after that 😞
Reb1sham2
Still no response....
I have the chat open since Oct 28th and
No updates nor response since the final response telling me I would be "Transferred" to ROI team
@Reb1sham2
Have you tried holding the reset button on the rear of the hub for a minimum of 30 seconds?
I am NOT a Sky Employee
Reb1sham2
The router is working fine just that the particular devices cannot reconnect after waking up.
My only solution is to power down /wait 1 min / power up
Pressing the reset button would achieve the same result
But does not sove the issue of disconnecting all other devices for the dutation of the reset / power cycle
@Reb1sham2
Holding the reset button is not the same as single pressing it or power cycling the router. Holding it will restore the router to factory settings and clear any gremlins out of the firmware. If the router wont provide IP addresses to devices after they wake up then its quite possibly a router issue so I'd recommend you try it.
Sky support will only tell you to do the same and then try sending you a fresh router, anything past that and you'll be on your own.
