Discussion topic: Overpaying for months – SKY still not providing Wi-Fi 6 modem
Message posted on 05 May 2026 08:09 PM
I’m using a 1000 Mbps fiber internet connection but I can’t get full speed over Wi-Fi. The maximum link speed I see is 500 Mbps.
From my checks, the connection is running on 802.11ac (Wi-Fi 5). My router is a Skyworth SR203, which apparently does not support Wi-Fi 6 (802.11ax) or 160 MHz channel width.
Because of this, even though I have a 1000 Mbps plan, I only get around 500 Mbps over Wi-Fi. I pay for 1000 Mbps but only get a maximum of 500 Mbps due to insufficient Wi-Fi provision.
I contacted customer support in March 2026 regarding this issue. I was informed that a Wi-Fi 6 modem was not yet available, but would be introduced in April 2026, and that I should get in touch once it had been launched. However, I have been unable to reach anyone at SKY to resolve this issue, and no one has responded to my complaint. A Wi-Fi 6 modem should be provided in line with my package.
I have effectively been overpaying for months because a Wi-Fi 6 compatible modem has not been provided. This is unacceptable. I will never use SKY internet again and will not recommend it to anyone.
Message posted on 05 May 2026 08:34 PM
Re: Overpaying for months – SKY still not providing Wi-Fi 6 modem
@Gokh wrote:I’m using a 1000 Mbps fiber internet connection but I can’t get full speed over Wi-Fi. The maximum link speed I see is 500 Mbps.
No company guarantees wifi speed due to the variables involved but that said, they've had the wifi 6 capable SR213 available for about 3 years now.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using the Deco WiFi
Message posted on 05 May 2026 08:37 PM
I should add that the SR213 (Sky Max Hub) is not renowned for the best wifi performance, I'd suggest researching a 3rd party mesh system and turn off the SR203 internal wifi.
Not a Sky employee
Message posted on 05 May 2026 08:49 PM - last edited: 05 May 2026 09:13 PM
I've no idea why they would tell you that: the WiFi 6 Max Hub was launched in July 2023
https://www.skygroup.sky/article/Sky-Broadband-releases-its-most-powerful-WiFi-yet
It's always been available to Sky Broadband subscribers currently using an SR203 who add the WiFi Max subscription supplement to their account.
Message posted on 05 May 2026 08:52 PM - last edited: 05 May 2026 09:16 PM
WiFi 6 has nothing to do with a 'modem': in this context that's the device converting optical to electrical (ethernet) signalling.
The SR203 is quite capable of delivering gigabit broadband: what you are referring to are wireless speeds, and that's different.
I'm afraid that's a fundamental misunderstanding, and no ISP guarantees anything like the same wireless speed as their faster FTTP connections can deliver over cabling.
For example, EE has a compensation threshold of 100Mbs wireless speed for users of its 1.8Gbs broadband, WiFi 7 'Pro' Hub and matching WiFi 7 booster hardware.
Message posted on 05 May 2026 09:20 PM
I 100% agree that they don’t guarantee the speed. However, they said they don’t have a modem that supports Wi-Fi 6 and have never provided one with my package. That’s the main problem. If they had provided a Wi-Fi 6 modem for a 1000 Mbps plan, I wouldn’t have made a complaint. The appropriate equipment should have been provided for the relevant package.
Message posted on 05 May 2026 09:41 PM - last edited: 05 May 2026 09:59 PM
New customers get the Max Hub. Existing customers who already have a Sky Broadband Hub keep that unless they add the WiFi Max subscription supplement.
That's just how Sky have chosen to do it.
Incidentally a WiFi 6 router is unlikely to deliver anything like gigabit wireless speed to an individual client device in real world conditions.
Message posted on 05 May 2026 10:01 PM
No matter what, the proper equipment should always be provided with the package. If you do not provide the correct equipment for the package you sell, you should not sell that package. You do not guarantee the speed, but you should guarantee that you provide appropriate equipment for the relevant package, especially to new customers.
Message posted on 05 May 2026 10:17 PM - last edited: 05 May 2026 10:35 PM
The SR203 is compatible with gigabit broadband because it has a gigabit ethernet chipset, and so Sky says it is 'appropriate'.
Message posted on 05 May 2026 10:28 PM
A Wi-Fi 6 modem is required for 1 Gbps internet. Please check the Wi-Fi standards. My modem only supports Wi-Fi 5.
Message posted on 05 May 2026 10:37 PM - last edited: 05 May 2026 10:43 PM
WiFi 6 is a wireless standard (clue's in the name ; ) and it says nothing about broadband.
The 'modem' for gigabit FTTP is the Optical Network Terminal, and that device doesn't have any WiFi at all.
Message posted on 05 May 2026 10:40 PM
From a technical perspective, a Wi-Fi 6 modem is required for 1000 Mbps speeds. It’s like fitting LPG to a petrol car. In theory, it prevents you from getting full performance from the system.
Message posted on 05 May 2026 10:48 PM - last edited: 05 May 2026 10:55 PM
You are missing the distinction between broadband and WiFi
Gigabit broadband is absolutely deliverable over gigabit ethernet: every ISP does that.
Gigabit WiFi might be possible with WiFi 7 source and client devices (and is almost entirely pointless for all practical purposes)
Modems are wired devices without any 802.11 rating
Your contract with Sky is for gigabit broadband, and broadband is what's delivered as far as the router.
Message posted on 06 May 2026 07:21 AM
You’re right about the distinction between broadband and Wi-Fi — I’m aware that my ISP delivers gigabit over Ethernet to the router, and that part is working as expected.
However, in practice the ISP-provided router (Sky SR203) is the only device I’ve been given to actually use the connection, and it only supports 802.11ac (Wi-Fi 5) with a maximum link rate of 866 Mbps (80 MHz, 2x2).
So while gigabit broadband is technically delivered to the router, the supplied hardware effectively limits real-world wireless usage to around 500–600 Mbps.
I understand that Wi-Fi isn’t guaranteed to match wired speeds, but providing a Wi-Fi 5 router with a gigabit package creates a clear bottleneck on the user side — especially when more modern Wi-Fi 6 hardware is widely available.
I’m not expecting full gigabit over Wi-Fi under all conditions, but I would expect hardware that can at least get closer to saturating the connection in typical use.
Message posted on 06 May 2026 07:31 AM
@Gokh whatever you choose to believe Sky simply doesn't agree and as far as I know neither does their regulator Ofcom. Sky will supply a SR213 WiFi hub if you buy their WiFi Max add-in but be warned while the hub offers WiFi6 for whatever worth the extender pods are only WiFi5 devices. In my experience the older SR203 you have will deliver around 650Mb/s in the area near by while the SR213 will hit 900Mb/s to a WiFi6 device but move two rooms away and the speeds are the same. Indeed in my home the SR203 had slightly better coverage two floors away so go figure. Actually both hubs are a bit meh to be honest and I have used both but choose to use my own WiFi kit to get stable WiFi coverage through the out my home as stability is actially more important than bandwidth..
By the way the Sky hubs are not "modems", that function is served by the ONT unit, the hubs are WiFi routers a totally different device. Your "gigabit" service is actually a shared connection where up to 30 lines sharing your distribution point share a 2.48Gb/s downstream link. That works because very few users ever use the bandwidth they buy for extended periods. Before you say Sky are crooks those specifications are set by Openreach and apply to every ISP selling full fibre using their lines..
