4
This discussion topic has been answered Discussion topic: Outage in Derbyshire?
This message was authored by: Witchypoo2
Hi. Does anyone know of any outage problems in Crich Derbyshire.  I cannot connect to broadband TV. I've tried all the usual steps no Joy. The amber light isn't even on on the hub. I've looked at service checker and there is a problem with my broadband,  just wondering if its a wider area problem and not just my address.  I carn't seem to find much information.  There where extreme thunderstorms in my area last night could this have anything to do with it. Any help would be very much appreciated.  I'm not very technical and it's very difficult to speak to someone at sky , so if its a area outage I won't need to contact them . Thank you in advance.
This message was authored by: cookiemonsteruk Answer
Re: Outage in Derbyshire?
@Witchypoo2
If the light is off completely usually means openreach have disconnected the broadband completely hopefully to work on it. Sky probably will get updated overnight.
@Witchypoo2
There appear to be issues in Matlock.
What colours are the lights on the sky router?
Avatar for Witchypoo2
Hi cookiemonsteruk.
Thank you for your reply. The two green lights are on my router, the power and the wifi, but the one in the middle that is usually amber when it's offline then turns green the internet light This is completely black no light at all. I've never experienced this before it's completely off?
@Witchypoo2
Oh, thank you so much!. That's a great help. So kind of you for taking the time to help me . Very much appreciated.
