Discussion topic: Our router keeps cutting out every 5 to 10 minutes
This message was authored by Andrew1312 This message was authored by: Andrew1312
The router keeps loosing broadband every 5 to 10 minutes
Re: Our router keeps cutting out every 5 to 10 minutes
@Andrew1312 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
