Discussion topic: Our Internet connection is frequently cutting out.
This message was authored by: PhilB1979
Our Internet was fixed some weeks ago but has now been cutting out a lot in the last 3 weeks. We currently have no WiFi.
Re: Our Internet connection is frequently cutting out.
@PhilB1979 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Avatar for PhilB1979
Hi yes we've tried that. It says everything is fine. It also said this when it wasn't fine a couple of months ago.
@PhilB1979  Can you follow the link below and pick your hub and follow what lights are on or a different colour and what directions of help are given.
