Discussion topic: Others with broadband “outage” in Dorset?
This message was authored by: Mike.Coulson
Had fibre installed on Monday and nothing but problems since.  Now today I'm told there is an outage in my area (Bournemouth) that could take 2 days to fix, but no neighbours are complaining about it.  Is this just an excuse?
This message was authored by: Poldek
Re: Others with broadband “outage” in Dorset?
We're in boscombe and have no internet
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Avatar for Mike.Coulson
Thanks - I tried that earlier and get errors trying to run it.  My mobile signal is poor at home, so that could be the reason.
This message was authored by: Emmasky2
We have an outage too and live in Charminster
This message was authored by: Jadmadsad
No broadband in Boscombe, it's been down since yesterday morning. For me that means no TV either. It took Sky 6 weeks to install after I moved here, and they repeatedly told me that Sky wasn't available in my area. I've only been connected a couple of weeks, and now there's a problem with it! What a joke!
This message was authored by: stevem242
We had fibre installed Tuesday. Friday 5th it went down completely. Told outage in area. Bournemouth. Apparently it was coincidence that there was a city fibre engineer outside our house.
