Discussion topic: Other provider installed Fibre - will Sky be able to use it?
Message posted on 17 Jan 2024 10:11 AM
BRSK have installed Fibre on my street, will Sky be able to use that installation in order to allow me to upgrade my package with Sky currently?
Message posted on 17 Jan 2024 10:13 AM
Re: Other provider installed Fibre - will Sky be able to use it?
Could you enter your full postal address below and post the table after removing your address from the image
No, Sky only use the Openreach network, as far as we know they have shown no signs of using an Altnets network.
Message posted on 17 Jan 2024 10:16 AM
After a quick check brsk build their own network so sky won't be able to use it
Message posted on 17 Jan 2024 10:26 AM
Message posted on 17 Jan 2024 10:35 AM
@cookiemonsteruk - thanks for your info! I was going to move to Sky Glass but looks like I wont be able too just yet.
Message posted on 17 Jan 2024 10:40 AM
Not on 16Mbps maximum speed
Message posted on 17 Jan 2024 10:42 AM
@Cshan2310 Just for your awareness you don't need Sky Broadband to use Sky Glass or Stream.
If there is a provider that can give you faster speeds than you can get currently the choice for me would be obvious.
Message posted on 17 Jan 2024 10:44 AM
Thanks for everyones help 🙂
Message posted on 31 May 2024 06:29 PM
I've got sky glass, and just got BRSK internet and the TV works spot on
