Discussion topic: Openreach don't have the equipment
This message was authored by: Isa1907
I have recently switched from another provider to Sky, and this is my first experience with your service. I have now been informed that Openreach does not have the necessary equipment in place to connect my broadband and phone line.
My current internet service will be disconnected on 18 August 2025, and I work from home. Any loss of service will cause disruption to my job and potential loss of income. This situation is unacceptable.
I expect Sky to urgently resolve this, provide a confirmed activation date before my current service ends, and arrange a temporary solution if necessary. I also expect appropriate compensation for any delay or loss of service, in line with my rights under our contract and the Automatic Compensation Scheme.
Please treat this as a formal complaint.
Re: Openreach don't have the equipment
@Isa1907 if you ordered your new service from Sky using the One Touch Switching service Sky will be handling the cancellation with your old provider which wont happen until the new service is live. However if you gave notice to cancel the old service uourself thst wont happen unfortunately. The one touch system was introduced to solve exactly the issue you have.
Avatar for Isa1907
I did not contact my old provider for cancellation, so I will still be online, which is good. However, being online only solves one problem. If Openreach provides this service, they should have the necessary equipment in place, shouldn’t they? I will already be waiting for two weeks, and who knows how much longer it will take.
Sky does not have its own broadband infrastructure: if an Openreach connection isn't available then it cannot happen.
Sky does not provide temporary solutions.
Delayed activation compensation should apply at the rate agreed by Ofcom.
It's not possible to register a formal complaint through this public forum
Not for a new FTTP installation: by definition that isn't 'in place' until the optical circuit reaches the subscription address and has an active ONT.
Avatar for Isa1907
Thanks for your input, but you’re basically saying “if the supplier can’t provide it, then tough luck”.
If that’s the logic, then perhaps the service shouldn’t be sold in the first place without confirming the infrastructure is actually available.
As customers, we buy from Sky, not Openreach, so the responsibility for delivering on time sits with Sky.
That’s exactly why Ofcom’s rules and Sky’s own contract make them accountable for delays — excuses about third parties don’t change that.
@Isa1907
Could you enter your full address below and post the notes below the table
It may give us a clue as to what equipment is missing and therefore timescales
Avatar for Isa1907
@cookiemonsteruk here's the screenshot.
@Isa1907
That shows a partial direct in ground solution ie they need to lay armoured fibre cable up to the house due to possibly no existing duct .  Possibly take unfortunately 2-4 weeks from the date of order
@Isa1907 Hopefully you recieved the e-mail also the T&C's and read all off the information and with the part that explains delay's!
Edit:- Info extracted from mine, so you can see.
Delivery of service
Many of our services are activated within 24-48 hours. However, in the event that further provisioning is required we expect your services will be available to you within 10-14 days. Based on this we expect your service would go live between 15/03/2025 and 19/03/2025.
Occasionally there are factors outside the control of Sky that may lead to delay. In rare cases where complex provisioning is required, or where issues occur, installation could take up to 90 days. In this event the latest your services would be activated is 03/06/2025.
When placing the order, the advisor will provide a provisional activation date which will be confirmed as soon as is reasonably practical.
If you are switching your services from another provider, we will confirm this during the sales process and explain the next steps then. Further information is available at sky.com/broadband-switch.
This is how the national FTTP rollout is proceeding: all Openreach client ISPs are affected the same way.
No, it doesn't.  By definition Openreach client ISPs have no way of installing their own bearer cable and are entirely dependent on the monopoly national provider.
Avatar for Isa1907
@TimmyBGood What we can not agree is none of them are my problem. At the end of the day, my contract is with Sky, not Openreach. I pay Sky, Sky bills me — so Sky is responsible for delivering the service on time. How Sky manages its suppliers is not the customer’s problem.
Avatar for Isa1907
@cookiemonsteruk  Previous tenant already had Sky here, it’s highly unlikely they now need to dig up and lay a whole new armoured fibre run.
@Isa1907
Previous occupier possibly had part fibre fttc .  Full fibre fttp takes priority when the exchange is enabled .
Working from home gives you no greater priority when using a domestic service, Sky nor any other provider will compensate for loss of earnings.
