Discussion topic: OpenReach engineer drilled a hole in the wall and left a loose cable
This message was authored by kellers This message was authored by: kellers
Hi,
We are due to have Sky broadbank installed. An OpenReach engineer came when I wasn't home and installed a cable to the outside wall (the cable is loose with nothing connected to it) and they also drilled a hole in the wall. I'm very concerned as the hole has been put on the wrong side of the house and is not accessible. They have drilled just behind the electricity meter. Is this normal procedure not to ask where cabling is to go? Either way they cannot put the cable there and would need it on the other side of the living room.
I'm not very happy at all that they didn't ask, plus they could have damaged the electricity meter. What is the next steps? Do they fit the telephone box to the cable?
Re: OpenReach engineer drilled a hole in the wall and left a loose cable
They shouldn't have drilled if there wasn't an adult present to give permission.
The location on the outside of the property is dictated by where the cable is coming from (duct or pole) : this isn't necessarily the same route as previous Openreach cabling.
Again, that shouldn't happen if there wasn't an appropriate adult present.
The new cable has to enter somewhere.  Where it goes from there is limited: they won't go through additional internal walls, for instance.
Clearly drilling should never be done 'blind'.
It would be helpful to establish if this is FTTC or FTTP installation.
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
