Discussion topic: OpenReach don’t have the equipment in place to connect broadband and talk
Message posted on 31 Mar 2025 07:42 PM
I ordered a house move with Sky on 10th March 2025 for a moving in date of 25th March. Engineer booked and on the day of 25th nobody turned up. Had a message in my Sky app (and a text message I hadn't seen as was busy with house moving) saying that OpenReach don't currently have the equipment to connect our new house (new to us but built in 1993). I called Sky and was told to wait until today for an update from OpenReach. They've said the same thing but an update will be on 8th April!
Blinking fuming and can't work from home with no internet (video editor).
I don't understand as my neighbours have quite clearly got a fibre cable going to the little grey box at the front of their houses so why can't we have one? I can't believe OpenReach don't have the required equipment since they've been installing fibre for a few years now.
Any help would be grately appreciated.
Thanks.
Message posted on 31 Mar 2025 07:54 PM
Re: OpenReach don’t have the equipment in place to connect broadband and talk
Notes from the search using link from a previous post:
Threshold(Mbps) WBC FTTC Availability WBC SOGEA Availability High Low High Low VDSL Range A (Clean)
44.5 30 8.4 6.3 27.4 Unavailable Exception VDSL Range B (Impacted)
43.8 26.2 8.4 6 20 Unavailable Exception G.fast Range A (Clean)
-- -- -- -- -- Unavailable -- G.fast Range B (Impacted)
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG premises served by 2.5 Inch plastic duct 56.
FTTP is available and a new ONT may be ordered.
As a fibre priority exchange, FTTP has priority over other products if available at the address
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
This site is in an FTTP priority area where FTTP is available but exceptionally SOGEA will also show as available to order but only at Non-Standard Premises (NSP) such as Hot site, Uninhabitable and Temporary locations. Migrations of WLR Solus (voice-only lines) is also allowed but only for SOGEA 0.5Mbps bandwidths. SOGEA 40/10 bandwidths order is also allowed.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Message posted on 31 Mar 2025 09:01 PM - last edited: 31 Mar 2025 09:03 PM
The relevant section is
Message posted on 31 Mar 2025 09:12 PM
I gotcha, so we can have it we've just got to wait for them to install it eventually?
Message posted on 01 Apr 2025 07:38 AM
@Number1Bassman essentially you are correct. Underground fibre supplies while neater than overhead supplies are more problematic as they often require extra work. How long it will take is impossible to know keep in touch with Sky to see what they have been told but they have very little limited ability to move things along.
My own underground feed hit issues and took far longer than planned. You should be accumulating compensation for the delay see Customer Auto-Compensation | Sky Help | Sky.com
Message posted on 01 Apr 2025 11:28 AM
The information in your check does not suggest any issue, my FTTP install has the same informational message.
Its possible there are other issues like your local fibre distribution point is full or the exchange has capacity issues.
