Discussion topic: Only getting 20 mps speed a lot of times supposed to be 500
Message posted on 31 Mar 2025 11:39 AM
My internet speed is terrible a lot of the time and I pay for full 500 fibre
Message posted on 31 Mar 2025 01:15 PM
Re: Only getting 20 mps speed a lot of times supposed to be 500
@Simonjj7 if you are testing the speed on a device connected by WiFi the figure you get is the slowest part of the transfer which is often the wifi speed in your home.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
