Discussion topic: ONT terminal water damaged
This message was authored by: Sian9017x
Message posted on 06 Aug 2024 05:01 PM
Hi I've had a decorator in and water from stripping the walls has stopped my ONT terminal from working. I've unplugged all wires and from the mains, will it dry out and be usable again? Or do I need it replaced? If so, who do I contact and is there a charge? Thank you
Find out more
Message posted on 06 Aug 2024 07:36 PM
Re: ONT terminal water damaged
You would log a fault with Sky for investigation by Openreach.
