Discussion topic: ONT Broadband and Service lights out
This message was authored by: Thailor
My internet stopped around 11am today, the City Fibre ONT lights for both Broadband and Service are out. I ran Sky's broadband trouble shooting checks and they say everything is fine (it clearly isn't). I've checked all the cables are in place and have powered both ONT and Router down for a while but same issue when powered back on. Any advice would be appreciated. Thanks.
Re: ONT Broadband and Service lights out
@Thailor
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
