Discussion topic: Not happy with my wifi
This message was authored by: Alan1235
WiFi keeps dropping off
Re: Not happy with my wifi
@Alan1235 depends on what you mean by "dropping off" if bybthst you mean the lights on the hub change because its connection to the exchange drops that requires action from Sky's end and should be reported
However if devices lose connection to the hub that is different. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
