Discussion topic: Not connecting to all rooms in the home
Message posted on 22 Nov 2025 06:04 PM
Message posted on 22 Nov 2025 07:32 PM
Re: Not connecting to all rooms in the home
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 22 Nov 2025 09:33 PM
@Perks86 Sky do offer that CHARGEABLE service were an Engineer comes out, takes a look see and advises what would be the best way to go about fixing up the required need!
You will have to call sky and arrange your request that way! Posting on the Forum does not make it happen!
