Discussion topic: Not connecting to WiFi and broadband
Message posted on 01 Apr 2025 04:07 PM
Hello,
since the weekend we have struggled to connect to our broadband and WiFi. We have reset the broadband constantly and it's still cutting out. Can you please resolve the issue?
Message posted on 01 Apr 2025 04:09 PM
Re: Not connecting to WiFi and broadband
@SamanthaMoran
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services.
