Discussion topic: Noise after fibreoptic installation
This message was authored by: KW221
  • There is horrendous sound in my house after fibreoptic installation. What can I do.
Re: Noise after fibreoptic installation
@KW221 what is causing the noise as both the ONT and the Sky hub should be entirely silent. Report the issuue to Sky. By definition fibre optical lines carry light so cannot cause noise.
This message was authored by: Toms2
Was this resolved? We are having the same issue it's driving us all mad we haven't slept probably for months
@Toms2  As mentioned by @Chrisee  Fibre optic cables carry light and doesn't creat a sound, if the noise keeps you awake are you sure it's your broadband equipment?
What kind of noise is it?
