Discussion topic: No wifi
This message was authored by: Tum10
No wifi
Is anybody WiFi off in yo30 area of york
Re: No wifi
@Tum10
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
