Discussion topic: No wifi yet tests say connections “good”
Message posted on 13 Nov 2025 02:09 AM
Sky Wi-Fi is down no internet access at all . But on app running tests says all is "good" and connected (obviously not) . Bit of a mick when that's what we're paying for and it's stopped with no explanation .
Message posted on 13 Nov 2025 05:18 AM
Re: No wifi yet tests say connections “good”
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it's not back, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
