5
This discussion topic has been answered Discussion topic: No wifi when sky says all good
This message was authored by: Pipkirk
At random times throughout both day and night (currently 21.32) the WiFi speeds drop to 2 maps when sky says i am getting 300mbps, clearly this isn't right. Additionally and what makes me even more incensed is while I appreciate replies, why are sky getting other customers to deal with their issues/questions when I want someone from sky to tell what the problem is. I wish I could attach screenshots showing the huge difference.
Re: No wifi when sky says all good
300Mbs would be speed arriving over optical fibre and ethernet cable as far as a Hub, not WiFi from it.
@Pipkirk You can attach screen shots, just use the camera icon and attach that way assuming that your level does allow that!
This message was authored by: Jan149
This is happening too frequently
No it didn't , more and more I am testing broadband and specially WiFi , it says it's good but no it is not , I have only 5 devices going at one time , a tv, a ring doorbell, Alexa and 2 phones, no computers , no game stations , why oh why do I keep losing WiFi ????
@Jan149
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
