Discussion topic: No wifi signal upstairs
Message posted on 06 Oct 2025 02:23 PM
I have little or no Wi-Fi signal in the top rooms in my house. I have run all the online checker tools and tests – they all say there is no problem but there is - Also, when the automatic test was done as a result of my telephone enquiry, the AI voice said that I appear to have an issue with the broadband set up, but this was not reflected in any of the online tests that I did. NB. I have Sky Max.
Message posted on 06 Oct 2025 04:41 PM
Re: No wifi signal upstairs
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
