Discussion topic: No wifi settings in My Sky App
This message was authored by: Galdukat
I have the Sky Wifi Max and i'm trying to change settings for the router. It says go to the My Sky App. I have done but only see Broadband Shield and Mcafee Internet Security. What am i doing wrong? Thanks in advance.
Re: No wifi settings in My Sky App
@Galdukat it sounds like Sky have not set up the a[p for you so I have escalated your post  to the Sky team who support the forum who should be in touch soon to offer you a private chat session to get this sorted. Keep an eye onnthe forum as if you miss the message just click the chat icon which will be added to the forum pages for you to use.saving a long phone call.
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to @Galdukat.
This message was authored by: Jack464
I am having the same issue
This message was authored by: TomDavies98
I am having the same issue.
Avatar for Galdukat
I can't remember exactly what i was advised to do, but it was along the lines of doing a factory reset on the sky hub and reinstall - It did work and the settings then showed in my app.
This message was authored by: Samyip
I have the same issue
I fixed mine by deleting the app and reinstalling it.
@TomDavies98 which is exactly the advice Sky give when people call with this issue although signing out, closing the app and signing in also seems to work.
@Samyip try that if it doesnt work you need ro call Sky to get it sorted.
