Discussion topic: No wifi on my printer
This message was authored by: Steve519
Before I had fibre optics my 6 month old hp printer was working fine now I can't install WiFi my laptop keeps saying printer offline
Re: No wifi on my printer
@Steve519 If you only did a fibre upgrade, then that would not effect the operation off a previously connected printer, and wi-fi is not installed on anything!
@Steve519 did you get a new hub when you switched to fibre? In my experience HP printers can be a pain to connect to a new WiFi router. Various methods can work first factory reset the printer by following the instructions on HP's support site for your model.
