Discussion topic: No wifi in parts of house and slow where we can get it
Message posted on 11 Nov 2025 11:55 AM
Wifi is very slow going down to kbps. Also because they moved the router when we had fiber installed we can't get any wifi in parts of the house that used to have it. Even with a booster.
Message posted on 11 Nov 2025 12:48 PM
Re: No wifi in parts of house and slow where we can get it
@Mikeseagerthe hub does not have to be near the new ONT unit so it can be moved if praxtical. The cable connecting the two is an Ethernet cable so can be replaced with a longer one if you want just buy one locally there is no speed loss as long as it is at least Cat5e.
WiFi speeds depend on the layout and type of construction of your home. Properties with solid internal walls can becreally difficult to network. Multiple wifi sources can work assuming ghry can get acdecent signal from the main router.
