Discussion topic: No wifi, Sky app says we are connected but we are not
Message posted on 16 Jun 2024 02:35 PM
Again we have lost wifi, i have used my speed check app and it says we are not connected, Sky app says all is good, but obviously it is not
Message posted on 16 Jun 2024 02:44 PM
Re: No wifi, Sky app says we are connected but we are not
@Sinned the test result is from the last routine test you need to click to run the test again to check the current position. What do the leds on the hub tell you see https://www.sky.com/help/articles/hub-lights-explained-start
Message posted on 16 Jun 2024 02:54 PM
I did do the test a few times, i have left everthing alone and it has now connected to the internet, for now.
Message posted on 16 Jun 2024 03:28 PM
Sky Max, is an automatic wireless channel selection, some of the channels on 5GHz that it uses are DFS, if radar is detected then wireless must be turned off or the channel moved to band A channel 36 or band C channel 147., this is a must requirement of Sky Max and other manufacturers wireless routers as DFS is secondary (most of the wireless channels on 5Ghz are secondary) and for home 5Ghz on wireless except two channels mentioned at 80Mhz width above are primary for home use.
