Discussion topic: No tv no broadband
Message posted on 14 Sep 2025 10:08 AM
No tv no broadband
No tv no broadband router has no light on
Message posted on 14 Sep 2025 10:10 AM
Re: No tv no broadband
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
