Discussion topic: No tv channels or broadband
This message was authored by: Emmab1252
I don't have any broadband and unable le to watch tv
Re: No tv channels or broadband
@Emmab1252
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
