Discussion topic: No tv and wifi
This message was authored by: GulsahH
No tv and wifi
My sky tv and wifi is not working, and I am unable to work without internet connection.
Re: No tv and wifi
@GulsahH
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
