Discussion topic: No sky broadband in Ladywood area
This message was authored by: Naren
Hi I am in Ladywood Birmingham.   My sky broadband just won't connect...anyone with a similar problem?
This message was authored by: Mikej163
Re: No sky broadband in Ladywood area
I'm having the same problem I spoke to sky and they ain't listening to me I've told then I have no Internet it comes on then goes off
@Naren @Mikej163
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
I've done everything and the check on the app and it's saying everything is good but it isn't
@Mikej163
Then it seems it's time to call Sky to report it.
Avatar for Naren
Yes I tried all the diagnostic processes....still doesn't work
