Discussion topic: No purple cable came with Broadband kit. How can I activate my broadband since my activation date up
This message was authored by: Frankie42
I received my sky broadband kit without a purple cable. I am unable to activate my broadband and my activation date is already running. How can I activate my broadband? Can I do so without the purple cable?
Re: No purple cable came with Broadband kit. How can I activate my broadband since my activation dat
@Frankie42
What broadband package did you go for superfast fttc or ultrafast fttp?
Has this been installed for ultrafast
If your broadband is still via a mastersocket you would need to get down to currys,pcworld, argos etc and buy a dsl rj11 to rj11 cable as sky doesn't supply them anymore
Avatar for Frankie42
As you suggested, I went down to curry's to get the R11 cable. However, the internet is still not working.  What might be the problem? This is really frustrating.
The open reach socket in my property is labeled master socket 5c OpenReach MK 4.  I don't know if the problem has to do with the socket
@Frankie42
Do you have any means of contacting sky if so contact them as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
