8
This discussion topic has been answered Discussion topic: No purple broadband cable when delivered
This message was authored by: Jessica0511
Hello!
I was just curious if there was a reason I had no purple broadband cable delivered with my sky box?
There is already an open openreach box & a power unit in the property, but when I had a message informing me my WiFi was active, it was 'connected without internet' & I was curious if the lack of a broadband cable is the reason for this?
Thanks!
This message was authored by: cookiemonsteruk Answer
Re: No purple broadband cable when delivered
@Jessica0511
The purple cable is a dsl cable for fibre to the cabinet sounds like you have fibre to the premises which uses ethernet from the fibre optic modem to lan port 4 on the back of the sky router (marked wan))
@Jessica0511
Avatar for Jessica0511
Thank you for the fast response!
Apologies, I'm no good with tech talk.
Does this mean I have to plug the sky box ethernet cable into the openreach box?
Thanks!
@Jessica0511
Does it look something like this
Older models can be a bit bigger
Kind of similar, unfortunately I'm at work so I can't get a photo.
I think it's an older model, it also has an additional power unit next to it on the wall.
@Jessica0511
Kinda like this where the smallerbox is a battery backup unit
Ethernet goes from one of,the ports on the larger box to the wan port on the sky hub.
Amazing!
I'll have a look when I go home this morning.
Thank you!
@Jessica0511
Have a good rest of the morning👍 Muggins here namely me has too much coffee and bouncing of the ceilinp 😁
It worked!
Thank you so much!
