Discussion topic: No or 1 bar signal in bedrooms after today’s install
Message posted on 01 Oct 2025 05:35 PM
Help with a signal test at all locations in my home
Message posted on 01 Oct 2025 06:07 PM
							Re: No or 1 bar  signal in bedrooms after today’s install
@Janestrang1 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
