Discussion topic: No one has fitted my WiFi
This message was authored by: Kerri211
No one has come out and fitted my WiFi they said an engineer would come out and set my WiFi up on the 3/04/25 and no one showed up then they said an engineer will come out on the 7/04/25 and again no one showed up and I've paid for it but no one has fitted my WiFi so it needs sorting bc I have a daughter who likes watching baby shark and she can't watch it bc sky haven't bothered to come out
This message was authored by: Jynxy
Re: No one has fitted my WiFi
Hi,
Just to get a better underdstand,
DId you have any confirmation emails or texts to say anyone was coming out
Was this a new installation or existing installation.
With above when did you get the router.
What service did you order
There is not normally a reason to come out and install when you turn the router on, the wifi should be already enabled, there is a card that will tell you the wireless name and password and you set that up on your device.
Sky Superuser - If i have helped you please mark as solution to help others. Thanks
1x Sky Q Silver - 1x Sky Wifi Max Hub - SKY Fibre Ultrafast.
