Discussion topic: No lights on sky max hub
This message was authored by: DiddyNicky
Message posted on ā03 Aug 2025 08:47 PM
Hi, my Internet is working perfectly but for a while now there are no lights whatsoever on the hub. When I first got it the lights worked. But now there are no lights at all, I've turned off/on repeatably but no lights whatsoever. š¤·
Find out more
Message posted on ā03 Aug 2025 09:46 PM
Re: No lights on sky max hub
On my previous hub the internet light use to be quite dim until it didn't show at all but it worked just fine. I suppose you have done a reboot so it is up to you what you do now, you could call Sky to see if they will send you a replacement hub and if they you will need to return this one:
https://www.sky.com/help/articles/return-tv-broadband
Add a note inside with your account number and a list of equipment you have included.
Make sure you get and keep proof of posting when sending this off.
