Discussion topic: No internet route has 2 orange lights, have reset several times. Run test says no issues
Message posted on 20 Mar 2024 09:43 PM
Message posted on 20 Mar 2024 10:01 PM
Re: No internet route has 2 orange lights, have reset several times. Run test says no issues
Same problem here.
Power - green
Internet - flashing amber
WiFi - green
Voice - amber
Have run tests several times today and each takes 10-15 minutes rather than 20 seconds and at the end Sky report no issues detected!
Message posted on 21 Mar 2024 12:08 PM
@Rocky1976 & @Dunkster74 Would like to understand which test you are running to check your broadband status and to see what is wrong from the links below which one you are using.
https://www.sky.com/help/servicestatus#/uk/issues
or this
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
