Discussion topic: No internet on Sky Q router. Gteen light not flashing
This message was authored by: rhino99
Message posted on 06 Aug 2024 06:10 PM
Been down over an hour and half no only 2 green light on q box
Find out more
Message posted on 06 Aug 2024 07:56 PM
Re: No internet on Sky Q router. Gteen light not flashing
@rhino99 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
