Discussion topic: No internet light on and not working
This message was authored by: MichelleOD36
Message posted on 28 May 2024 08:19 PM
Lights on power and WiFi internet not working
Find out more
Message posted on 29 May 2024 07:06 AM
Re: No internet light on and not working
@MichelleOD36 the lack of a green internet light indicates the hub is not connected tomthe cabinet. If yourcservice is still down this morning using a mobile connection log into the My Sky app and run the connection testif it tells you nothing is wrong ignore that which is from the last routine test and click to run it again. If it telss you there is a onown fault in your area you will have to be patient as itvwill be fixed as fast as possible. If it doesnt call Sky and report tge fault.
