Discussion topic: No internet despite all green lights on SkyQ hub and tests found no faults???
This message was authored by Gareth00001 This message was authored by: Gareth00001
My internet is not working despite having all green lights on my SkyQ hub and MySky App tests saying no faults found. My TV says there is no connection and my phone does not connect online. How do you report it as it just says everything is fine when it is not!
Re: No internet despite all green lights on SkyQ hub and tests found no faults???
@Gareth00001  Have you tried to just restart the router to see if it clears this issue?
Gareth00001
Yes I have restarted the router and used all of the usual steps from the help pages.
@Gareth00001If the turn off and turn on does not work, you could try the 1 hour turn off and then see if you are given that new IP address and see if this does cure your issue.
