Discussion topic: No internet connection to hub
This message was authored by: Ky10
Hi, my internet connection to my WiFi has just gone for half an hour now. I've reset everything and followed instructions in your site but it still hasn't fixed it. Now none of the lights are appearing for the internet, WiFi or voice. Before they were appearing as orange but now not coming on at all. The app is not doing well either at showing there is a problem with my broadband or wifi, as it says it's working perfectly fine but it's not. All devices that were connected to the WiFi is no longer connected to internet.
Re: No internet connection to hub
@Ky10
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
@Ky10
If it still down later then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
