Discussion topic: No internet connection on Sky q box
This message was authored by: Simonly1
All green lights on the router but my phone or my Sky q box will not connect.
Re: No internet connection on Sky q box
@Simonly1 there.can be an issue which gives these symptoms which is caused by a fault in the server managing your connection. Either force a disconnection by using the hub's web interface or power it down for an hour which should clear the fault.
