Discussion topic: No internet and amber light on
Message posted on 29 Apr 2024 08:08 PM
Internet was working fine then went off. Light on box is amber
Message posted on 29 Apr 2024 08:12 PM
Re: No internet and amber light on
Same here happened out of nowhere and not coming back on
Message posted on 29 Apr 2024 08:14 PM
@Chads & @Holz1103 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Could also check the service checker when running the broadband test to see if it gives you further information.
