Discussion topic: No fibre broadband
This message was authored by: Rohcho
No fibre broadband
The WiFi and wired connections are not working. Sky q mini boxes not working due to no internet. Sky app says everything is fine but nothing is connecting and even phones are saying no internet connection. Having to use data roaming for last 3 days
Re: No fibre broadband
@Rohcho
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
@Rohcho You may wish to run the service checker as it may indicate a area fault if not then you need to call sky!
