Discussion topic: No devices connect to wifi
This message was authored by Kirky4776 This message was authored by: Kirky4776
My sky q connects however no mini boxes or mobile devices connect or find the router.
Re: No devices connect to wifi
@Kirky4776 reboot the hub. Has anyone made any changes to the hub's set up as they may have hidden the SSID in which case you can reset the hub by pressing and holding in the reset pin until the poower led flashes.
You can log into the hub with the SSID which is hidden by choosing the "Other Network" option on most devices and entering both the SSID and password - the default details are on the hub's label.
