Discussion topic: No devices can connect to the Wi-Fi (access point full or disabled errors)
This message was authored by: JANIGEES
After resetting my router and checked the connection all is fine and the router has 4 green lights, however no devices are able to connect to WiFi which I can see because it has 0 devices connected on the app. The error messages that come up are Access point temporarily full / disabled. Not sure what is wrong but it is incredibly frustrating. If anyone can help I would greatly appreciate it.
Re: No devices can connect to the Wi-Fi (access point full or disabled errors)
Hi @JANIGEES
Try factory resetting the hub by holding the reset button on the rear for 30 seconds.
If this doesnt resolve it I suspect you have a faulty hub.
I am NOT a Sky Employee
