2
This discussion topic has been answered Discussion topic: No connection issues yet Sky states everything looks good
This message was authored by: Caz361
This is becoming a regular occurance! No SKY connection, yet checks states everything looks fine
Re: No connection issues yet Sky states everything looks good
@Caz361
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
@Caz361
Avatar for Caz361
Thank you @DanielO210, I got it working again, but no doubt will happen again so good to know for future reference.
